Some items in your cart are discounted for members. Log in to claim them!
Отстрани ставкаThumbnail imageПроизводЦенаКоличинаМеѓузбир
× EXTENSION PSU KIT PHANTEX ATX 24-pin, CPU 4+4-pin, PCI-E 6+2-pin x2, 30cm w/cable clips RED, PH-CB-CMBO_RD 13333 EXTENSION PSU KIT PHANTEX ATX 24-pin, CPU 4+4-pin, PCI-E 6+2-pin x2, 30cm w/cable clips RED, PH-CB-CMBO_RD 3.150 ден
3.150 ден
× WEB CAMERA LOGITECH MX BRIO 4K/30fps USB Type-C, Grey, 960-001554 WEB CAMERA LOGITECH MX BRIO 4K/30fps USB Type-C, Grey, 960-001554 15.270 ден
15.270 ден
× CASE FRACTAL DESIGN ATX Mid-Tower NORTH, 2x140mm Aspect 4-pin PWM fans, w/WINDOW TEMPERED GLASS DARK, Side Mesh+Front wood panel, Charcoal Black, FD-C-NOR1C-02 CASE FRACTAL DESIGN ATX Mid-Tower NORTH, 2x140mm Aspect 4-pin PWM fans, w/WINDOW TEMPERED GLASS DARK, Side Mesh+Front wood panel, Charcoal Black, FD-C-NOR1C-02 10.050 ден
10.050 ден
× COOLERS CASE FAN 140mm ARCTIC P14 PWM 1700RPM, 4-pin, WHITE ACFAN00222A 36287 COOLERS CASE FAN 140mm ARCTIC P14 PWM 1700RPM, 4-pin, WHITE ACFAN00222A 870 ден
870 ден
× NET LAN USB 2.0 10/100, BLACK, TXA041, Chipset: RTL 8152 17206 NET LAN USB 2.0 10/100, BLACK, TXA041, Chipset: RTL 8152 410 ден
410 ден
× CABLES USB 2.0 AM-BM 3,0m 13031 CABLES USB 2.0 AM-BM 3,0m 150 ден
150 ден
× CASE FRACTAL DESIGN ATX Mid-Tower NORTH MOMENTUM EDITION, 3x120mm Momentum 4-pin PWM fans, w/WINDOW, Front wood panel, Charcoal Black, FD-C-NOR1C-05 CASE FRACTAL DESIGN ATX Mid-Tower NORTH MOMENTUM EDITION, 3x120mm Momentum 4-pin PWM fans, w/WINDOW, Front wood panel, Charcoal Black, FD-C-NOR1C-05 11.950 ден
11.950 ден
Вкупно во кошничка
Меѓузбир41.850 ден
Вкупно41.850 ден (вклучува 3.029 ден ДДВ 18%, 1.048 ден ДДВ 5%)
